Topic: Seeking outside door trims (Read 1444 times) previous topic - next topic
I am looking for these two door trim pieces (not sure what to call them :)  for the passenger side.  I've marked the pieces that are on the driver's side for reference.  Need the 'smooth' ones, not the 'ribbed' looking ones.  If you have a set, please let me know and we'll go from there!  They're the only outside trims that my Cat still needs.
THANKS!
X
1986 Mercury Cougar XR-7 Turbo-charged 5-speed.
Owned 22 years.
Quote from: CougarGal;456341
THANKS!
X
i have a clean set driver/passenger.  I won't separate them, but $75 for the complete set.  Just let me know.  They need paint but are very clean and straight.  I will post a few pics tonight.
THANKS!!  Will check back later to see pics!!
Owned 22 years.
David,
After careful consideration, as much as I'd like to have the two I need, I just can't swing $75.00 right now to also get two that I don't, and will hopefully never need.  Once I get past the current 'have-to' repairs, I may be able to change my mind and will give you a shout when the situation changes a bit.  Thank you SO much!!
Owned 22 years.
The fear of splitting the set is that i get stuck with the other half.  Im not actively selling parts so let me know if you need them going forward.  Good luck with the Cat!
