Topic: 1995 SN95 spindle swap (Read 1905 times) previous topic - next topic
When using the SN95 spindles with the stock 85 thunderbird struts, which side of the spindle/strut mount should the spacers (washers) be on? Front, Back or evenly between?
Even.
You will also need to put spacers (roughly 5/16") under the ball joint castle nut.
Got it, Thanks!
