Topic: Mini tub (Read 6715 times) previous topic - next topic
Mini tub
Well I'm back at the transplant project for the 85 turbocoupe
Im tossing around the idea of mini tubbing it.
Is it worth doing?
What width rear tires are you fitting under the factory wells?
The car is going in to get thru floor frame connectors with webbing to rockers, plates for future cage.upper & lower boxes,ARB and coil-overs
I have built motor for boost but will run N/A for now.
It's 410ci iron eagle with Vic Jr's thru a JW glide.
I may have to run a c4 i have for now depending on how far I can stretch the budget..
Cheers
Mini tub
Depends on how you are gonna drive it. I drove with 275/60's on stock ten holes, but they did rub a bit. On my 87 they only rubbed on max travel.
That's roughly a 28x10.5" tire btw. I think a 26x10 would be fine.
Mini tub
It's gonna be my street car for now
I have a bullseye 483, holly hp but due to budget constraints
I'm not going to be able to go forced induction right now
Im sure the car will have a few ponys once complete.
I dont want any rubbing that's forsure.
Mini tub
Stock tires are about 25.5" tall and about 6" wide tread width. The rubbing for me was because the tires were too tall, not because of width. I did have to zip tie the brake cables.
Mini tub
Good to know...thanks
How was the rake with the 28's?
Mini tub
Where you rubbing on inner wheel well?
Do you think you could have corrected it with changing back spacing of rim?
Thanks
Mini tub
Not really, it was basically as much room as avaliable. If you rolled the fenders, you probably could fit 325mm or wider tires, but it was pretty close to the control arm and outer fender, it was centered pretty well.
It rubbed on the very outside of the tread, where it transitioned to sidewall on my setup. Put a few deeper grooves in the side when I had a couple hundred pounds in the trunk, just light rubs when empty.
Mini tub
I will be using offset LCA's and I have a slightly narrowed rear so sounds like I should be good once I figure out my backspacing for my setup.
Thanks for your input Haystack
Mini tub
We have a wheel/tire thread here somewhere. Just remember that the 87-88 cars have more wheel well then 83-86 cars.
Mini tub
My 86 had very wide tires on the rear, Firehawk F1's on 16" CSA'S. I can't remember the size tho...they were the rain tires for firehawk racing series. I got a set from my buddy's dad who was the mechanic on team. 20 years ago anyhow, I know they were a short tire. I'll get under it and measure best I can...worst case scenario I mini it and throw a bigger tire under it.
Mini tub
A 10.5W will fit under the car with stock wheel wells if you roll the fender lip and massage the inner fender.  Other than that you will want to mini tub the car for anything larger and if you are going to do anything other than straight line race it.
Mini tub
I run a 275/60/15 drag radial on the street and 28x11.50 Hoosier QTP at the track. Wheels are 15x8 with 5.5" backspace. Never rubs but I also have the rear seat deleted and don't really put anything in the trunk. I also have coilovers all around with 150lb springs in front and 175's in the back. Might go back to 150's on the back.
TC#1- 2.5T- 10.14@134....9.76@138 with a 50shot
TC#2- Turbo BBF project
TC#3- parts car
Mini tub
It should be noted that 87-88 cars have more room in the wheel wells.
Mini tub
Quote from: Haystack;456366
Doh, didn't see that OP is working on a 85'.
TC#3- parts car
Mini tub
Thanks guys!
Ford made the wheel wells larger in 87-88?
Anyone know off hand the actual measurement on difference between the 86 vs 87?
