Topic: fox steering shaft interchangeability (Read 2724 times) previous topic - next topic
Would a fox mustang steering shaft fit in a 88 cougar?
88 Cougar
88 T-Bird
other cars that don't apply to this forum
I would say yes.  I have an SN95 Mustang power steering rack in my 83 with the Maximum Motorsports hybrid steering shaft and it all bolted right up.
Thanks man im gonna order a used mustang shaft and have a u joint welded in in plane of the rag joint
88 Cougar
88 T-Bird
The power racks use a different spline and size shaft then manual racks, as long as it's a power to power swap or manual to manual it should work fine.
I can verify that it works, I put a mustang shaft on my bird and it fit fine.
84 TurboCoupe with 302 .010 over - 9.8 : 1 Forged Pistons - Edlebrock Goodies:  Aluminum Heads #6037, Intake #3821, 65mm TBI/EGR #3824/3827, Camshaft #3722 -  Interactive System & Technologies Mass Air with 24# Injectors - A9L - 3g Alternator - BBK shorties, Cat Converter H-pipe, Magniflow lers - World Class T5 1352-169 (1986, V8, WC, 3.15 3.35 1.93 1.29 1.00 0.68) OEM Clutch Cable - 7.5 Trac Lock with 3.08 and slapper bars from 82 Mustang.
Quote from: The Hawk;456147
Yes.
I have a Maximum Motorsports MMST-11 shaft on my Bird (as well as MMST-7 rack bushings).....fit perfect.
http://www.maximummotorsports.com/Steering-Shaft-Assembly-Power-Steering-Rack-1979-93-Mustang-P980.aspx
Cool. This is something I want to do. Pure old fashioned laziness is the only thing stopping me from swapping the MM piece in.
Is there any additional road noise or vibration transferred to the steering wheel with an aftermarket shaft?
