Topic: The Cougar Saga (Read 2157 times) previous topic - next topic
The Cougar Saga
New to the Foxbody platform, former happy owner of several Panther platform cars but nothing this old. Snagged this for $400.
So, the deets!
1986 Mercury Cougar 5.0 SEFI unknown automatic.
99,500 miles
The good:
Engine runs well, lots of power.
Shifts nice, but do not like how regardless of throttle input I don't get 2nd until 20mph.. Trying to find TB cable adjustment procedure
All interior/exterior lamps work as intended except for a few warning bulbs (door ajar, low washer fluid)
Transmission somewhat recently rebuilt.
The car drove from the owners to my home under its own power (40 miles) after sitting for 6 months. Pulled the plugs, squirted some oil in the cylinders, and it fired right up!
The bad:
2 rotten brake lines. Haven't done a full inspeciton but saw two holes. Going to be a PITA as the fluid is black and thick...I'm thinking I might wind up replacing the calipers and flushing the new (and old) lines. Rear brakes work, once you get to the floor
Temp gauge reads cold at all times and I can't find the sensor for it. Found the ECMs' sensor, but not the gauges'.
Ignition switch needs to be replaced. Must be fiddled with to keep speedo/radio/accessories on.
Various broken vacuum lines. Repaired a few, but need to get more vacuum line.
HVAC blower seems weak, and sounds as if there may be some leaves blocking the intake. I checked the cowl and it looked fine...I can't even see the blower to take it out and see whats up??? this seems concerning. Please tell me this isn't like doing the blend door actuator on a grand marquis where the dash has to come off (or partly, anyway.) Upside: A/C compressor engages and blows cold, and heat blows hot..
The Cougar Saga
Should shift into second at 14mph with a light pedal, should shift into 3rd about 25 and od 42-44mph. Make sure the TV cable is connected, this will kill the auto aod trans in just a few miles.
Blend door on a 88 crown vic is much the same as a blower motor. You do not have to remove the dash, but it can make things quicker and easier. If you have the manual lever heater controls, it is much easier.
The Cougar Saga
Replace the ignition switch asap. That's a fire hazard in the making even without the key on.
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
The Cougar Saga
Sounds like a nice start.  Pics when you can, and welcome.
Mike
