Topic: ANyone using SN95 coils? (Read 8146 times) previous topic - next topic
I have a set of new factory 95 Cobra coils Im planning to use in my car but Im curious if I should install them as is or will they need to be cut a little prior to install?
Wanted to know who was using sn95 coils and if they cut them or not and how much. Pix help too...
Brian R.
88 2.3t Ranger
Sn-95's have about an inch less travel and are about an inch shorter. Vinnie is running sn-95 coils all around and I like his stance.
sweet good to know!
Brian R.
88 2.3t Ranger
I think Vinnie used coils from a convertible Mustang? ( not 100% on this) But he was using air shocks in the back to get the desired ride height. Agreed Vinnie got it right though...Looks awesome.... By the way "deathbypsi" great build I'm following. Cant wait to see it complete., Ray
 S O L D
I'm using SN95 Stang springs. The ride height was good already after the swap. I got about a 2 inch drop. perfect. I added the air shocks (as I always use) to maintain the rear height when I have my heavy toolbox and part weighing down the car.
Thanks for the input Vinnie. Exactly what I was hoping to hear.
Brian R.
88 2.3t Ranger
Mine actually came from a V-6 car if I remember right. I read a chart of the V-8 and V-6 springs, they were virtually the same thing. I got mine from a local yard. They worked better than I had hoped.
Mine were pulled out of a 95 Cobra when it was brand new still for drop springs so they been sitting in a box for decades. I hope these will provide a sporty ride at a height that looks good
Brian R.
88 2.3t Ranger
Pretty sure they will be too low in the rear, unless you address that.
Mike
Quote from: mcb82gt;455707
Yup. My Thunderbird has 98 Mustang GT springs all around. The fronts are equivalent to 87-88 Turbo Coupe factory springs so they will be fine. The rears are short though. I have adjustable ride height rear control arms from Maximum Motorsports and I had to crank them about half way up to match the ride height from front to back. You'll tuck the rear wheels way up with the stock rear control arms.
I was considering making my own weight jackers for my stock lowers when I rebushing and box them so maybe I will make that a for sure thing to do now.
Brian R.
88 2.3t Ranger
Same setup as Vinnie.  2k GT fronts, 2k1 V6 convertible rears.  Invest in Maximum Motorsports caster/camber plates, you WILL need them.  Unless you think there's any reason you really need -2.5 degrees camber (ask me how I know).
I'm running 96 gt convertible rears and just the stock 87 turbo coupe spring up front with 5/8 coil cut
Has a nice drop but in the future I will probably drop it more
Also note that I also have a huge box and sub in my trunk
From what I've heard on the rear sn95 springs,  the convertible springs have a higher spring rate
Here ya go:
98 Mustang GT springs rear (with polyurethane spring isolators) with Maximum Motorsports extreme duty adjustable rear arms (turned half way up). Moog 8598 springs (with polyurethane spring isolators) in the front. Stock style strut mounts in the front as well. With 26" tall tires there is slightly less than a 2" gap between the top of the tire and the wheel well lip all around. Aligned perfect with no caster/camber plates.
