Topic: Odometer and trip meter quit. (Read 2208 times) previous topic - next topic
1996 XR7 speedo still works. If any have experienced this please tell me if it is possibly a ground problem. I am pondering taking the instrument module out and polishing all the contacts to see if that will fix it. The tranny sensor must be working because speed is still indicated. Any help is appreciated.
Bobbydsp
Generally that's a gear failure inside the cluster... Lots of Fords of that era had same issues...
Thank you.
Thanks. I will try to find one in a wrecking yard. I may also get a new electronic speedo. Do not know how that would look.
A junk yard cluster will likely have same issue, replacement gears are avail in aftermarket... Used to regurarly see them on ebay...
I ordered the two gears that most likely are the problem today. Southern Electronics is the business I ordered them from Just so happens they have a store here in Richmond, VA. I will post my results when I get the job done.
Bobbydsp.
