Topic: WTB working PCM E3ZF-12A650-AIA 1983 2.3T (Read 903 times) previous topic - next topic
Hello, This is my first (newbie) Day on this site. Been a Member of LOD (same user) for years and appreciated the TBird, Cougar, Mark body style since becoming a FLM tech in 1986.
I own a 97 Mark VIII, a 68 Cougar and recently acquired a Barn Find 83 Turbo Coupe. I will update my profile when I can.
As the Title says, the TBird is running but didn't idle due to PCM not supplying enough ground. Found a PCM locally and that repaired the idle (IAC) but will only run unless the spout disconnected.
Please reply or send PM if anyone can help me out.
My first Post and I didn't follow directions. I do apologize for my over sight. If you would Delete this Post I will re-post in the proper Place!
Not starting out right, I'M I!
