Topic: no spark problem need help (Read 2461 times) previous topic - next topic
this morning i tried to start my '88 5.0L to prepare for the first ride of the year and the car don't make any spark from the coil. I tried my new accel super coil, plugged red wire on + and green wire on - and nothing, do i have to interchange wires or remove the inline resistor on green wire? Yesterday it just ran fine and today no spark, really frustrating.
Any kind of help is appreciated as i never plugged aftermarket supercoil on any kind of car and don't know much of ford ignition.:toilet:
The stock coil is probably fine, they rarely fail on these cars. It's probably your ignition module (the little gray plastic "box" on the side of the distributor).
CoogarXR : 1985 Cougar XR-7
Have you checked the primary and secondary windings on the old coil ?.feed coming to the coil?. Do you have a tfi module if so my money would be on that.
Or, we could actually see what's wrong instead of throwing money out the window.
http://sbftech.com/index.php/topic,588.0.html
Do everything here and you will either be driving away or know what's wrong in 10 minutes.
While your at it, run codes. I run codes with a paperclip. Any questions, come back and we will be glad to help.
finally the car started and the coil was ok but at first when i did the tests of the sbf page it drove me to a bad coil. put another one and bam it started, reinstalled previous coil and it's fine. Kinda bizzare situation:wtf:
1000 to 1 on the TFI...
I've replaced one tfi module and pip out of 11 cars I've owned. And I replaced a msd aftermarket tfi module that had failed.
I'm with Tom.....the TFI is going out.
At least get a spare, some contact goop, and the little socket to swap it. It WILL fail, usually when you least need it to happen. ;)
