Topic: LED Taillights (Read 4564 times) previous topic - next topic
LED Taillights
Here is a short video of the LED taillights in my black bird. I had previously re-painted the reflectors a bright silver. I had thought about using some chrome vinyl wrap I have to make them brighter. Whatcha you all think? These bright enough or should I do the chrome wrap.
https://onedrive.live.com/redir?resid=28412C1F39D26D27!572&authkey=!AGBX9vvU3vbR1C0&ithint=video%2cmp4
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
LED Taillights
Little hard to say but they look bright enough to me. Any chance you can put stock bulbs on one side for a better comparison?
LED Taillights
I can do that :)
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
LED Taillights
Ok, so i reinstalled regular lights in the left taillight. To me, it appears just slightly brighter but not as red. I have red LEDs in the right side.
https://onedrive.live.com/redir?resid=28412C1F39D26D27!574&authkey=!AJdgdTpXGITm0A4&ithint=video%2cmp4
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
LED Taillights
Yeah, the regular bulbs seem to have a slight bit more intensity. The LEDs certainly seem like enough though.
LED Taillights
Why not white LEDs? The lens is red anyway.
That's why the std bulbs look brighter, most likely.
LED Taillights
Quote from: Chuck W;454947
White LEDs and the regular bulbs tend to make the lenses look pale. You  can't see it in the video though. With red LEDs, the red is more  brilliant, more red, more intense....
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
LED Taillights
what bulbs did you use, so we can try to compare to others.....
LED Taillights
Yes with leds you want to pick the color desired regardless of the lens color
Regular bulbs produce a larger range of wavelengths an the lens then filters out the rest
Leds produce a very small range of wavelengths, so a white bulb will be less bright after being filtered through a red lens compared to a red bulb in a red lens.
LED Taillights
Quote from: jc10000rpm;454965
I used regular silvania 1157 bulbs and the LEDs I picked up at my local Pep Boys, the brand is Pilot. I had another type of LEDs that only had the leds facing outward (when sitting in the socket) and they didn't work very good.
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
LED Taillights
Or the "plasma" leds. Plasma doesn't mean anything, just marketing bull .
