Topic: Help with Type Of Thermostat for 3.8 V-6 Engine (Read 1382 times) previous topic - next topic
Hi Guys
    I wanted to get a new thermostat for the 3.8 V-6 motor but everyone I ask gives a different model so I do  not know which one is correct?
here is a list of thermostats I have been given
Are they all correct for the car?
84 V6 thunderbird Thermostat compatability list
Stant 13009      180 degree ??  list says 195 degrees
GATES 33508  192 degree
Gates 33509  ??
motorad 7244-192 fail safe thermostat
MotoRad High Performance Thermostat - 2000-195
Motorad 244-192  192 degree
Motorad 200-195 195 degree Thermostat
NAPA 269
Can anyone suggest a good ( thermostat model # ) for the car?
Those are just different manufacturers.  They should all work.  Avoid the fail safe and go the a 192-195 degree unit for a stock application.
Quote from: V8Demon;454683
+Juan
DO NOT use a fail safe thermostat. See here as to why: http://www.foxtbirdcougarforums.com/showthread.php?39214-engine-running-too-cool-*solved-installed-non-failsafe-tstat
