Topic: 84 3.8L - Engine Races in Wet Weather (Read 1995 times) previous topic - next topic
Hey have 84 Tbird with 3.8L, 71K miles.  When in the rain or at car wash, engine will race intermittently whether driving or idling. Any thoughts as to the cause??  Thanks.
My first though is a TPS or ISC failure that is moisture induced. Could be an open circuit in the harness that moisture shorts out. Have you checked for KOEO and KOER codes? Might narrow down to TPS or ISC.
Agreed, next time it's raining and it's racing, use the paperclip trick to pull codes. My guess is the tps, but the readout should tell you.
Hi, thanks.  How do I check codes on this car?  It doesnt have an amber light as I recall.  Thanks alot.
Quote from: softtouch;454670
You don't have a check engine light
Code definitions here: http://www.thorssell.net/hbook/2digit.html
Here you go:
Thanks alot.
Here's a YouTube of me running codes on my car. Takes all of 5 mins.
Koer test 1987 tbird: http://youtu.be/9QSiS6wf7oU
