Topic: I'm a NEWB (Read 3519 times) previous topic - next topic
I'm a NEWB
Hello
I have a question  I own a 1985 Cougar 2 door hardtop 5.0 engine. It this a fox body or the fox body chassis  I am having a hard time  dispersing all the different information I am finding on the internet  Also I am not sure on the model . It says Cougar 2 door on the title No LS  or GS
Thank you for any help
Kim[ATTACH=CONFIG]37328[/ATTACH][ATTACH=CONFIG]37329[/ATTACH][ATTACH=CONFIG]37330[/ATTACH]
I'm a NEWB
Welcome
I'm a NEWB
Welcome aboard.  Yes you definitely have a fox body.  89 up was the mn-12 platform.  80-88 would be the fox bodies.
If you want to learn about your car, stick around this forum and head over to http://www.coolcats.net.
I'm a NEWB
Welcome to the forum. What are your plans for the build?
I'm a NEWB
Thanks guys.. Ok I have been poking around on the car On the inside of the passenger door is a tag. It's starting to fade but it's there  I know it's the tire size stats. What I am surprised at is it says Model XR7  I thought this was a 1985 Cougar. What is the diffrence if any. Sorry as the title says I am a newb I should also include the title  says series Cou2D  I am pretty sure that means Cougar 2 door No xr7 ect ? X
I'm a NEWB
Xr7 means turbo charged 2.3. Its a generic tag for different tire sizes available that year.
More likely then not you have a base or gs 86 cougar. The Ls model is just a different trims and standard options. A gs or base model can be almost identically optioned out in these years. Mine is a base, but my first car was a gs and had less options.
Poke around on coolcats.net they even have model info by year and Vin information.
I'm a NEWB
Welcome:cool:
I'm a NEWB
Quote from: ilyu2;454386
Hello
Kim
Hello and welcome.
Based on your pictures, and assuming that its exterior has not been modified; it is not an LS. Two easy to identify exterior features of the LS model were bright rocker panel moldings and the electroluminescent coach lamps on the c-pillar (the Cougar emblem lights up).
BTW, for 1983-1985 model years, there was no GS designation, just Cougar, Cougar LS and Cougar XR-7. The GS model designation didn’t start until the 1986 model year.
One of 1,246 built
