Topic: Bit of curiosity here (Read 2426 times) previous topic - next topic
What size is the throttle body opening on the SO upper intake?
88 Cougar
88 T-Bird
other cars that don't apply to this forum
50 mm.
Mustang H.O. is 60mm.  90's 5.0 Explorer/Cobra Mustang/ "GT40" spec is 65mm.
The intake opening is closer to 60mm on the SO uppers I've seen, throttle body and EGR spacer are 50mm... HO opening are larger than SO...
Oops yeah he did say "on the intake". Would make sense that the intake manifold itself would have a slightly larger opening.
Intake manifold openings are as follows:
SO upper is ~60mm
HO upper is ~65mm
Explorer/GT40 upper is ~70mm
Neat thanks guys
88 Cougar
88 T-Bird
....and the Trick Flow Streetheat/Trackheat pieces have a 75 mm opening if anyone wanted to know.....
