Topic: tps help (Read 5434 times) previous topic - next topic
tps help
Hey everyone my 88tc been idling crazy so figured tps needs replacement which is no big deal but did some checking around can't find one. Does anyone know where to find one I've checked Autozone,O'Reillys,Napa no one has one in stock or in warehouse. Can the sensor b interchangeable?
tps help
First you should run codes and see what is actually causing the problem.
tps help
Quote from: Haystack;454027
+1
tps help
Theres no check engine light and I've heard if ppl having problems with tps and it not showing codes
tps help
It will show up when you pull the codes. If it's the tps that is. That'll show you whatever sensor is acting goofy.
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
tps help
Well I guess I'll test it but I bout know that's problem I don't mind buying and replacing cause wat it does is sometimes it jumps up to 2000rpm sometimes higher shut engine off fire back up idles fine then it will do it again but pass couple days it's been alright but tomorrow my be different I'm not trying to be difficult I appreciate help but if I run codes and it reads tps then I still have to find one that's y I asked if anyone knows where I can get one car does have several problems and it has done this sense I've had car 3yrs now so figure whats another 30-50 bucks lol
tps help
Rockauto.com
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
tps help
AFAIK they are all about same, if it fits it works... I used one from my Bird on my '93 Lightning when it failed, fit and worked perfectly...
tps help
Thanks I didn't know were about to get one been searching found bbk tps at jegs and summit 50 bucks and I wondered if they were same if it fits. Thanks for info
tps help
Quote from: 1badbird;454059
rockauto.com
x2
Mike
tps help
Hey OP, had the same problem with my 88 tc. Guess what??? A tps probably won't fix it.... Throw one on it tho. The parts stores love people who troubleshoot by changing parts willy nilly.
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
tps help
Seems like you're saying the car is trying to hunt for an idle
 The idle speed controller may actually be carbon'd up on the inside
 Use a cheap buttstuffog meter and unplug your TPS
 Manually increase and decrease your throttle body linkage and watch the needle on the meter move
 You measure from the black and the green and open your throttle slowly to maximum a couple of times
 Next you test from your green wire to your orange and open your throttle and watch the needle movement
 You do this test with the TPS unplugged and the car off
 You're looking for a smooth sweeping motion of the needle on your meter
 You set your meter to something like our times 5K or are times 2K
 If at any point while your meter is measuring and the needle is interrupted you've confirmed that the TPS is faulty
 No plug the TPS back into your harness and go back to the front of the engine
 With a stick pin probe the green wire physically bypassing the stick pin through the conductor
 Switch your meter to DC volts and the maximum voltage you  are working within his the 5 V DC scale
 Picture red lead to the stick pan and your black lead to battery ground
Start your car up and you should see about one volt DC within acceptable range of .7 to .9  volts DC at idle
tps help
Anything from .59-1.27v's at idle should be fine and 3.5v's above idle at wot.
My cougar was sitting at 1.25 volts for a year or two before it finally through a tps code. Im pretty sure it was the original with 320+k miles on it.
tps help
Key on engine off, 1987 bird codes.: http://youtu.be/z0ehA8cFTkc
Koer test 1987 tbird: http://youtu.be/9QSiS6wf7oU
Test ran by yours truly using a paper clip and an old school buttstuffog meter. You can use a test light or a sound buzzer if you like. It litterly takes 2 minutes start to finish.
