Topic: Dyno Day is finally here.... (Read 7210 times) previous topic - next topic
Saturday morning, the Sport gets strapped down for a few dyno pulls. I have NO idea what the power will be. SO, I'll post the results when I get home. I've been waiting for quite a while. It's at the local tech school, and the instructor is a high school friend of mine. It's good to know people.
285 at the wheels is my guess.
Good luck!
That may be a good guess. I want at least 300, but, that may be reaching. Hoping the engine combo can do what it's supposed to do.
Let us know Saturday how it turns out!
I'll post the results and a ic of the sheet. In reality, probably 148 hp at the wheels.
Quote from: vinnietbird;453630
150hp Vinnie. Don't cut yourself short ;)
The horsepower wasn't what I thought, but the torque was more than I thought. Scott (dyno operator) said the air/fuel mixture was right where it needs to be. Horsepower was 276 and torque was 349. It's good enough for me I guess. LOL.
Ah, I was 6 HP off. Oh well...
Not bad, got the graph??? If the dyno is calibrated correctly HP & TQ will be same at 5250 RPM, your TQ seems a tad high...
Also remember driveline loss is at least 15% to as much as 18-20%...
I had a stroker windsor in 1999 that made a little over 500hp on the engine dyno and a shade over 350 at the wheels once in the car. Still ran 11.30's in the 1/4 mile at 3300 lbs. I know guys that claimed over 400 at the wheels that still couldn't run the number. Dynos will vary drastically depending on design and correction factor.Should still be alot of fun.
1988 LX, 306 with GT40P heads, Downs Upper Intake on Truck Lower, Powerdyne Supercharger and T5 swap.  Scavenger Hunt Build at it's best.
291hp/349 torque at the wheels is pretty good. You're looking at around 350hp at the flywheel.
Nice numbers Vinnie :burnout:
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
I often wonder if the 70mm throttle body is big eough. He did say that the air/fuel was just about perfect. Nut I still wonder if a 75 would help at all.
https://www.facebook.com/avery.pigg/videos/1281297281886562/
Way cool Vinnie!!
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
