Topic: Vacuum release for emergency brake 85 bird (Read 1753 times) previous topic - next topic
Where can I find and replace the vacuum switch for the emergency brake release?
Where is it located. Where can o order one
I believe it is on the colum shift hardware under the dash.
 Most of the time it is the plastic vacuum lines that get brittle and break.
correct,,
my little check valve failed on me one day and i had a huge vac leak under the dash.
i pulled over and quickly bypassed the auto ebrake and have not bothered hooking it up since.
better engineering money could have been put towards a drink holder solution if you ask me,, LOL
you will find the same pieces parts in other ford cars,, but no i have not found this part in parts stores yet.
Oddly , my ford bronco has the same check valve setup for some reason but it does not have auto ebrake.
The check valve on the bronco is for the cruise control deactivation. When you have the cruise on and press the brake pedal is drops the cruise out.
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
