Re: need power
Reply #1 –
First off, you don't have a governer on your 87. I see you're looking for ricer solutions, get that out of your mind. If you throw a fart can and a huge wing on the back, you'll catch a lot of flak for it, especially from me. The upgrades you undertake should be dependent on how much you can do yourself or how large your budget is. Forget about the turbo, it won't bolt up without major modification and the 3.8 isn't a very good candidate for forced induction because of known head gasket weaknesses.
So far I have upgraded the throttle body with the v8 version, replaced the clutch fan with an electric one, and removed the smog pump. All of these added together are pretty good for few ponies. My next step is installing stock headers from a 93 'stang and going full dual exhaust. Do all of those things and you'll have a pretty reasonable power increase for less than a couple hundred bucks if you do all the work yourself.
For a little more bump, you could have it bored out and throw some rods and pistons from the 4.2 truck motor in there. No one has done that here that I know of. You're getting into slightly more expensive territory and at that point you may want to toss a v8 in.
