Topic: Help with wiring of 6 bank clip on distributor,on 1984 thunderbird 5.0! Please! (Read 1717 times) previous topic - next topic
Hey guys I need some help with hooking up this clip on the distributor, it was hooked up and run with tape!!From the person before me.. So I heat shrinked one at a time I thought, but now I have zero spark,  so I'm guessing I screwed up somewhere.. This was a car from my late uncle that has passed and means alot too me..So you're help is very much appreciated Thank you...
Can't quite picture what you have going on there.
Maybe this will help:
There are replacement plugs available, all that should be necessary is match color...
BTW I do know wiring is different colors on E/F series and maybe other vehicles as well, I believe Mustang & Fox Bird are same...
Thank you guys! I had the wiring all right didn't have some other clips hook up on the driver side! Now I have spark tested it on a light that shocked the piss outta me!! But still not starting?? Sprayed started fluid and it fired on that and I revved it trying to get it to catch and stay running. But no luck?  I watched the injectors spraying gas in to the bowl but won't start? When I parked the car it ran? Any suggestions
And I replaced the ground on the battery to the engine, and the positive wire to the solenoid..And put 5 gal of 91 octane with Lucas fuel treatment and it won't start?
