Topic: 88 tc line help (Read 1834 times) previous topic - next topic
88 tc line help
X I need to know what this line is on my turbo it's on the horn and I don't know where it hooks up to
88 tc line help
That line  goes to the breather on the valve cover
88 tc line help
Thank you very much as you see it's broken off can I 're plumb it using rubber vacum line or do I need to find a oem
88 tc line help
Yes you can use rubber hose
88 tc line help
I need help again lol what is supposed to plug up to the e in the vacuum treeX
