Topic: Hi, its my first time here... (Read 2438 times) previous topic - next topic
Hi, I have an 87 cougar ls and today I was stopped at a drivethrough and when I started to pull away I heard a loud sputtering type noise and it lasted about 10 seconds.  It sounded as though it was out of water, but that wasnt the case. It didnt start to overheat or anything.  I checked all the fluids and everything is fine. This car has been great, I have had no problems with it except I had to replace the water pump before. My car only has 64,000 miles on it. Please help if you know what this could be, it might be nothing, but i am no mechanic. Thank you!!!!!!!
Re: Hi, its my first time here...
what kind of sputtering noise was it. were did it sound like it came from?
It sounded like a loud shhhhhhhh noise with a kind of poping in it. Sorry that is the only way I can describe it. I dont know much about the mechanical part of my car, I just know that I love this car.
mine just started making a noise that i think is like that. ill have to start it tomarrow and see cant start it now. dont want to wake everyone in my house. but the first thing i thought of is a Creaking Door does this sound right?
No I think it was coming from under the hood.  I hope it was nothing. I guess I wont get too worried unless I hear it again. I hope your noise is nothing major, good luck.
I'm guessing he was comparing the sound to that of a creaking door, not actually the door making the noise.
1987 Thunderbird 3.8. Sold :(
yea your right but mine comes from it sounds like my tranny she is talking about under the hood
OH DUH!!!!!  Sorry, I understand now.  lol
vacuum line? sucking air somewhere maybe
if your talking about mine no it sounds like my tranny. not a vacuum line
Quote from: 88SptCoupe
nah I was talking about her car...
my car makes a humming sound @ like 35mph...the AOD tranny
It might have been, thanx I will check into that. But I am happy I havent heard it since.
86Tbuzzard already said it, but it sounds like you probably have a vacuum leak somewhere...I know I had a vacuum leak on my car when I had this hose disconnected, and it made a noise like what you're describing.  Sort of a hissing noise with a few hiccup sounds, made the engine run pretty poorly too.  If it is a vacuum problem, the best thing to do is put your head under the hood.  Look for any disconnected hoses and see if you can pinpoint where the sound is coming from.  The only real way to tell, unless it is an obvious leak, would be to take it to a mechanic and have them check vacuum pressure in all the vital spots.  Hope that helps and good luck.
Thank you for all the suggestions. I really appreciate it. It is nice to know that I can come here if I have any questions.
