Topic: 1988 thunderbird lx 5.0 h/oodifed (Read 1905 times) previous topic - next topic
X
Not OODIFIED But MODIFIED LOL
Default 1988 Thunderbird 5.o H/o Conversion done ! But I have an issue ?
1989 5.0 H/o in a 88 Tbird automatic ! Spark jumping ISSUE !
Well to start with please keep in mind I did not do the install of this MOTOR into my car !
I bought the car and had to complete the work ! Used cool cats site to complete it !
1989 Mustang 5.0 H/o
The rest of the conversion has been completed by me !Per Hot rod Mag conversion sheet
A9p performance ECM
Maf Pigtail
5.0 air tube and maf combo tube
Now this car had sat for more than 5 years
why because they could not get it started ?
Turned out the IGN switch had separated so I replaced it and after replacing the fuel pump it started right up !
There are no codes so my issue is with
The minute we went to set the timing Bam I got the shock of electric of my life !
So Later that night in the dark
I fired up the engine
The light show started at the first 3 plugs on each bank !
So today I added a ground strap to the engine
And still I have arcing ?
I touched the side of the COIL
And Bam I got the shock again !
And yes it kinda hurt !
So I have New
Dist cap
Wire's
Engine control module
pickup coil
Rotor
Etc:
Iam At A lost
I did not hook up this motor so Iam behind the 8 ball on this !
Anyone got an Idea ?
Thanks ahead of time !
Mods are on going !X
still hammering out the spark issue !
Old spark plug cables will leak out and create a lightning show. Spark plug wires have a certain resistance to them, when they age resistance goes up and the pixies inside the cable try to find a way out. I have actually heard of a few high end expensive wires having this problem from new out of the box. I'm not saying you an update do this, but you should be able to comfortably touch plug wires with no arching when the engine is running. Seeing a light show at night definitely leads me to believe they should be replaced.
I'd try a cheap replacement set. I think I paid $17.99? For my last set, and its good to have a few extra wires laying around.
