Topic: 4 eye head light replacements? (Read 2185 times) previous topic - next topic
Any alternatives to the original 4 eye sealed beams that are DOT approved?
Thanks
you should look into the H4 conversions! And LateModelRestoration.com has some good h4 headlight units.
I run some early chinese halo conversions. I am sure they are not DOT, but they are much better than the ol' sealed beams, and they aren't obnoxious to oncoming traffic.
I wish I would have waited until the LED halos came out, they look cooler than my incandescent (read: dim) halos.
CoogarXR : 1985 Cougar XR-7
These are DOT and are what I have in my Bird:
http://www.racinglab.com/sealed-beam-h4666-ns2211s.html
Here is the thread on the install:
http://www.foxtbirdcougarforums.com/showthread.php?31691-New-Diamond-Head-Lights-for-the-83
I have since pulled the higher wattage bulbs.  I got concerned with both getting a ticket and the housings getting hot.  Neither of which happened but why press my luck on something stupid like that.
Darren
Quote from: Aerocoupe;452345
Darren
......thanks. Good info.
