Topic: Anyone running Strange 10-way struts, Mach1 Springs, and MM caster camber plates?? (Read 3178 times) previous topic - next topic
If so what spacers you running with your MM caster/camber, and how much strut shaft you have past the nut? See pic
I didn't measure the stock height as a refrence when I was putting the car together.  I'm going over the car now before taking it for allignment and realized I have more strut shaft on one side than the other so my spacer choice on one side is wrong.  Just curious what everyone else with this combo uses.
On my driver side I have only 1/4" of strut thread showing, and driver side has about 1/2".. so I guess I used that little space underneath cause the tops are the same.
Im running that exact combo but will have to look when I get home I just don't remember.
87 TC
Cool thanks, I was going to PM you last night.. I seen an old post of yours while searching
I have 98 mustang springs,  94 mustang struts, and MM CC plates.  I have it setup as the one really small spacer and a full sized spacer up top.  The rest of them 2 full sized and the half sized one on bottom of CC plate bearing.
84 TurboCoupe with 302 .010 over - 9.8 : 1 Forged Pistons - Edlebrock Goodies:  Aluminum Heads #6037, Intake #3821, 65mm TBI/EGR #3824/3827, Camshaft #3722 -  Interactive System & Technologies Mass Air with 24# Injectors - A9L - 3g Alternator - BBK shorties, Cat Converter H-pipe, Magniflow lers - World Class T5 1352-169 (1986, V8, WC, 3.15 3.35 1.93 1.29 1.00 0.68) OEM Clutch Cable - 7.5 Trac Lock with 3.08 and slapper bars from 82 Mustang.
Thanks,  I'm curious to see which spacers bigbada1 is using.. probably just about the same
post 173 and post 188 on my build page, I wish I would I have seen this earlier
cool thanks,  I got some catching up to do on your thread.. car looks great!
