Topic: Car won't start after MAF conversion.. (Read 2673 times) previous topic - next topic
I have triple checked to make sure every pin is in the right number.  Would the fuel pump relay or VSS keep the car from actually starting?
We are beginning to believe we may have gotten a bad computer.  Any ideas guys?  Thanks
'88 Thunderbird LX
Engine:  FR B303 cam, GT40P heads w/ Trickflow valve springs, Explorer upper/lower intake, SR cold air intake w/ MAF
Exhaust:  shorty headers, BBK O-R X-pipe, glasspacks w/ turn downs
Misc:  8.8 rear, Saleen SC replicas 17x8/17x10, Mach 1 front springs/SN95 rear springs
'74 F100 Custom 351W
is fuel pump coming on with key cycle?
Yeah, I hear it when I turn the key.
Quote from: thewestie;451765
'88 Thunderbird LX
A few weeks ago my bird wouldn't start. Had spark, fuel, etc... Turned out to be a bad ground from the computer. Good luck with it. Electrical Gremlins can sometimes be nerve racking
 S O L D
Quote from: GDawg148;451764
VSS nor fuel pump monitor circuit will cause a no start, neither will TAB/TAD solenoids as the Ford Racing conversions didn't address their wiring... If fuel pump is priming it's either a injector drive issue(computer), or there is no ign pulse to ECM tell it when to fire injectors...
Stick the orig computer back in it to see if it starts(be sure to reconnect vac to MAP)...
So.........any updates? I hate a story without an ending.
:popcorn:    Im curious too  :popcorn:
 S O L D
