Topic: battery wires (Read 2301 times) previous topic - next topic
battery wires
just wondering where the negative wire connects to
Re: battery wires
Somewhere on the side of the block if I remember right.
85 Tbird 5.0
78 F150 351w
13 F150 4x4 3.5 Ecoboost
Re: battery wires
On the 5.0? Right near the oil filter and oil pressure sender, if they're all like mine. Just saw it today while putting in a gauge set.
Re: battery wires
would it make a difference if you had a 3.8 like i do
Re: battery wires
On the 3.8 it connects near the front/bottom of the block on the passenger's side to a stud.
Re: battery wires
easy to get or no?
Re: battery wires
Go out and have a look.  I'd help you out, but my car's about 2 hours away waiting for a new heart.
1987 Thunderbird 3.8. Sold :(
Re: battery wires
I accessed the cable from below. It is easy to get to, but you need to jack the car up a few inches unless you can slide under it without any lifting.
Re: battery wires
ok,, it connects in two spots if its the factory cable.  It will have a lug that connects to the engine block near the motor mount.
following the wire up towards the battery, you will find some insulation removed and a lug crimped on in the areas where is can attach to the side of the actual frame.  follow the cable up higher and you will see where the battery terminal is.
so,, it connects in two spots.  if it did not,, there would be a higher resistance in a lot of your ground circuits than you would like due to the isolation the motor/tranny mounts present.  there is also a wire mesh ground coming off the back of your head(s) which is attached to the firewall.
