Topic: Fuel sending unit float hanger wire (Read 2906 times) previous topic - next topic
need exact angle of the fuel sending unit wire that drops from the variable resistor to the float.
there is a bend / elbow that has been messed with by little tots (my boys) years ago and I want to re-bend and make it right.
someone has to have a fuel level sending unit lying around!
I can find one tomorrow, and give you an angle, or better yet, I can trace it exact and post the pic to follow
thanks,,  I can print that out
I appreciate it
Here ya go....
glad I could help
Cool, i need that also.  Jcassity do you have your trunk cut out to allow quick access?  I do but still need to pull out the sender and adjust.
84 TurboCoupe with 302 .010 over - 9.8 : 1 Forged Pistons - Edlebrock Goodies:  Aluminum Heads #6037, Intake #3821, 65mm TBI/EGR #3824/3827, Camshaft #3722 -  Interactive System & Technologies Mass Air with 24# Injectors - A9L - 3g Alternator - BBK shorties, Cat Converter H-pipe, Magniflow lers - World Class T5 1352-169 (1986, V8, WC, 3.15 3.35 1.93 1.29 1.00 0.68) OEM Clutch Cable - 7.5 Trac Lock with 3.08 and slapper bars from 82 Mustang.
