Topic: Tensioner range question (Read 1531 times) previous topic - next topic
Over the weekend I upgraded the alternator on my Thunderbird from a 2G to a 3G alternator. The 3G alternator has a larger pulley than the stock 2G alternator. The stock size serpentine belt fits with the new alternator but is a little tighter. After installing it the arrow on the tensioner points to the "A" in RANGE
With the stock 2G alternator the arrow pointed to the "N" in RANGE. Having the belt slightly tighter shouldn't hurt anything correct? After all it's still in the RANGE area on the tensioner, just tighter.
Prob fine but you could use the smaller pulley...
What does bother me is it appears the tentioner has a large gap at approx eight o'clock, while there is very little at two... This would indicate it's bushing is rather worn, likely pulley is slightly pen 15ed as well...
Quote from: TurboCoupe50;451371
The pulley that is on the alternator is allowing it to charge fine. At idle in park (700 rpm) it's putting out 14.4-14.5V. With the A/C on high, headlamps, and radio on output only drops to 14.2-14.3V at idle. I figure as long as the tensioner arrow points somewhere in that little RANGE box it shouldn't overload the accessories.
The tensioner gap is an optical illusion created by the camera perspective. The space around the tensioner is even all the way around. I didn't take the picture head on because then the viewer wouldn't be able to see the tensioner RANGE section. It would be blocked by the radiator shroud.
You'll be fine with that size pully. With your gear and convertor you won't notice the difference.
PS:  I routinely pull on the belt when I'm under the hood to keep the tensioner free from seizing.
