Topic: rear disk help (Read 1869 times) previous topic - next topic
rear disk help
so swaped in 89 linc mark vii rear end new calipers and rotors and pads hooked everything up but not sure how to get them to bleed cant get any fluid coming out of the calipers
rear disk help
I remember the same thing happened to me and I just had to unscrew the bleeder a little bit more
BTW do you have the abs teves system, if so for the rear brakes only you just hold the brakes and the abs unit pump does all the work for you
rear disk help
no abs they were very loose
rear disk help
are you getting fluid to the  splitter block on the rear?
rear disk help
gonna have to find that out tomorrow when i removed rear end i just bolted up new rear end after cleaning and tried to bleed
