Topic: Turbo Engine Swap (Read 11911 times) previous topic - next topic
Turbo Engine Swap
Hey all. I'm new to sight and was hoping to get some info.
I have an 88' Turbo with a tired engine. Always planned on replacing with a carbureted 302 cid but would rather do a 5.0 FI out of an 89' or newer mustang. I know the engine will bolt in but wasn't sure how much wiring, if any, would match up. I figured on getting a donor mustang for all necessary parts/pieces !!
Also, what parts are needed to bolt the Turbo Coupe 5 spd to the 5.0 ?
I'm guessing one of you gearheads out there have mad this swap so I'd really appreciate any help with some or all the above.
I've always thought Ford should have made that combination available from the factory........but they didn't ask me, sooooo.........
Thanks for any help,
TTFARMS
Turbo Engine Swap
Welcome!
Ford did make available the 5.0 HO in the '87-'88 Turbo Coupe body. This was a special order only "off highway" and came with no warranty. Cost? 27K. Btw, this topic has been discussed on this site before. As for your subject at hand, its best to get ALL your parts from a donor 5.0 car, including wiring, brackets and such. I do not recommend using the 4 cyl. T-5. Others may chime in for more intimate details on the swap. Have fun!
Turbo Engine Swap
Thanks crossboss.
I tried to find info on the sight but guess I need to dig deeper in the older posts. Just hoped to get web sights, potential problems addressed and odd ball parts gathered before I tear into it.
I'll take all the help I can get. Don't want this to turn into on of those "long term" projects !!
Interesting about the "off highway" car. I'd never heard about it but I'll definitely do some research. Thanks
Turbo Engine Swap
Quote from: crossboss;451061
Welcome!
Do you have documentation to support this? I highly doubt these cars would be produced by Ford on the regular Thunderbird/Cougar assembly line but, if they actually existed, were instead put together by an outside vendor.
Turbo Engine Swap
thunder jet…
Oh, boy here we go again…Yes, Ford did offer/sell the "off hiway" only 5.0HO T-Birds. I personally was going to order one in 1988..cost 27K. If you may recall (or not) this topic was discussed before. Bob "Bondo" Bondurant had several Dark Blue T-Birds at his driving school in Arizona at that time. Many magazine articles were done on his cars and how you can order one yourself. These cars were not advertised in the brochures, just like the current CJ Mustangs. They were sold only for off hiway use and came with no warranty. Upon delivery, you had to trailer it off the dealers lot. A bit more trivia thats really not known, '87-'88 Birds could have been specially ordered in the LX body with 5.0 HO engines, only with 4 speed auto transmissions. How do I know this? My mom special ordered one in 1987..we still own it today. Its a hell of a good car.
Turbo Engine Swap
Quote from: crossboss;451068
thunder jet…
The Bondurant cars were modified, not built on assembly line ...
I'd sure like to see that sales contract or at least the VIN for engine code that proves it has a HO vs std 5.0...
Hot Rod tested a 1987 T-Bird and commented "it'd surely be nice with a HO", Ford flatly stated it wasn't going to happen...
Turbo Engine Swap
Yeh, Like I believe what Hot-Rod magazine says…I know, I worked on Hot-Rod TV.
Bondos cars were modified versions for endurance road course track use by Jack Roush. The "production" versions (if you want to call them that) did not have the blue printed 5.0 HO engines, 5 lug wheels, roll bars, and such. Special ordered HO 5.0 engines DID come like I mentioned in the LX body with automatics only (no Turbo Coupe bodies), as these were already emission certified/crash tested in use on the same Fox platform, e.g.: Lincoln MK VII LSCs. Also, the 5.0 HO engines only had speed density, not mas air injection, just like the Lincoln's. Forgot to mention, Bill Elliott Ford offered a "special, limited production"  5.0 HO Cougars for sale in 1988.
Turbo Engine Swap
Quote from: crossboss;451070
I know you're full of shiznit now, Bill drove T-Birds, won the Winston Million in a T-Bird(1985), the Championship in 1988, and he sold Cougars??? As I said --- Bull shiznit...
Turbo Engine Swap
:popcorn:
 S O L D
Turbo Engine Swap
:popcorn:
Turbo Engine Swap
As a note all SEFI 5.0 HO V8s from 1986-88 were speed density, except California 5.0 Mustangs which got MAF in 1988. 1989 and up 5.0 Mustangs were MAF but the Lincoln Mark VII stayed speed density till the end of production in 1992.
As for the rest, including being able to order a LX from the factory with a 5.0 HO I need some proof, or I call BS as well.
Turbo Engine Swap
:popcorn:
Turbo Engine Swap
Turbocoupe5.0--
It amazes me the idiots on here. I am fully aware Bill Elliott raced Fords. Apparently, you have no clue when you say someone is "full of it" Do your research, and you will see that I am correct. Come out to California, and look at my moms car first hand..I will leave it at that, so you can make more of a fool of yourself.
Turbo Engine Swap
Here is the VIN on my moms 1987 Bird: 1FABP62M2HH158XXX. Now you tell me "I'm full of it"
