Topic: Need help identifying MAF sensor.. (Read 2552 times) previous topic - next topic
I didn't think this was a stock sensor, but you guys tell me.  Wouldn't it say Ford on it?
Who made it? Will it work fine? A friend gave it to me.
X
'88 Thunderbird LX
Engine:  FR B303 cam, GT40P heads w/ Trickflow valve springs, Explorer upper/lower intake, SR cold air intake w/ MAF
Exhaust:  shorty headers, BBK O-R X-pipe, glasspacks w/ turn downs
Misc:  8.8 rear, Saleen SC replicas 17x8/17x10, Mach 1 front springs/SN95 rear springs
'74 F100 Custom 351W
I have no idea. Perhaps an aftermarket part. The ONLY factory Ford MAF sensors and housings that are plug a play with a Fox MAF computers are the 55mm housing with the F1ZF sensor (stock on 89-93 5.0 Mustangs) and the 70mm housing (Either the housing stock to 94-95 Mustangs or the housing stock to 94-95 Thunderbirds/Cougars. You can swap the F2VF sensor into the Thunderbird housing so it will work with the factory stock Mustang airbox and tubing.) with the F2VF sensor (all 94-95 Mustang, 92-94 Crown Victoria, Grand Marquis, Town Car). Any other factory Ford MAF will not work without a tune.
Aftermarket MAFs (C&L, PRO-M, PMAS) are calibrated to an injector size by manipulating the signal sent to the computer to scale the airflow for larger injectors. Ford programs the injector size into the computer NOT the MAF. Hence why you can't take a MAF off of a Lincoln Mark VIII with 24lb injectors and expect it to work with 24lb injectors on a 5.0 Mustang.
If you are running 19lb injectors I do happen to have a 70mm MAF with the F2VF sensor sitting in my garage. PM me if you want it as I have no use for it right now.
To my friends knowledge, he pulled it off of an 89 5.0 and its stock. So it must be an F1ZF?
'88 Thunderbird LX
Without a Ford part number, it's no doubt aftermarket...
Vatozone special
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
Do you guys think its aftermarket but to be used in place of stock? As in it performs the same as stock?
'88 Thunderbird LX
Quote from: GDawg148;450993
As long as it's the same as the stock one it should. Since there is no part number it's hard to tell.
