Topic: Dome light wiring (Read 1723 times) previous topic - next topic
Dome light wiring
1987 20th anniversary
found some mice nests in my back seat and blower motor, pulled everything out and am noticing my dome light is not working anymore.the light does not work with the door or manual switch's but the lights under the dash still come on when the door opens.
anyone have a idea if there is a plug under the pass side dash i may have missed or if the light is grounded through the front seats seat belt assy that i removed for cleaning.
Thanks
Dome light wiring
Map lights work? they use the same ground and a different pin in the same connector C415.
The connector is below the EEC behind the passenger side kick panel. Either a 4-pin or a 2-pin connector depending on features.
The black/light blue wire.
