Topic: Explorer Intake vacuum lines... Car idling badly... Help (Read 5445 times) previous topic - next topic
I just need some help on what I can cap off and what I absolutely need to run so that the car will idle better.
X
If I put my finger over the larger hole, the car shuts off.  So I know I need to run it.
X
Thank you!
'88 Thunderbird LX
Engine:  FR B303 cam, GT40P heads w/ Trickflow valve springs, Explorer upper/lower intake, SR cold air intake w/ MAF
Exhaust:  shorty headers, BBK O-R X-pipe, glasspacks w/ turn downs
Misc:  8.8 rear, Saleen SC replicas 17x8/17x10, Mach 1 front springs/SN95 rear springs
'74 F100 Custom 351W
Are you maf already?
There shouldn't be any vacuum leaks or un capped ports at all. Everything before should be hooked up.
Just cover any vacuum ports you're not using with vacuum caps. That's pretty much it.
Edit: Does this help?
Quote from: Haystack;450637
I have yet to convert the car to MAF, but I have everything needed to.  Could that be the reason for the funny idling?
'88 Thunderbird LX
Quote from: thunderjet302;450638
What is the meaning of the tape?  Are those the places that can be capped off?
'88 Thunderbird LX
Stock configuration vacuum lines.....
If you're having an issue where the car shuts off by capping a vacuum source that has been deleted and have not removed the MAP sensor from the equation, you need to reset the base idle.  Leaving that port open to the atmosphere is introducing a rather large vacuum leak.....
Since you are still running Speed Density, it is necessary to run the line to the MAP sensor.
Quote from: GDawg148;450653
A B303 cam is going to run really choppy on SD. I'm a bit suprised it idles at all.
Been following this thread. I notice GDawg's signature says he has a "58mm throttle body" ?? Shouldn't he be running a 65 mm? Could this be part of the problem?
 S O L D
Quote from: ISTLCRUZ;450673
Nope. A too small throttle body won't cause that issue. A B303 cam/SD/vacuum leak will though.
