Topic: Familyso's beater truck issues... (Read 11806 times) previous topic - next topic
So my father in law has a 95 F150 beater truck with a 302 in it. It's a standard cab long bed, 4 wheel drive automatic. 272K on the clock. Purchased off eBay some 5 years ago, it's run fine ever since. So, 2 years ago, it blew a trans line and leaked all the fluid out. Got it towed home, figured, with that many miles we'd rebuild it. So we pulled the trans. E4OD I believe it is. We rebuilt it over last fall, then we figured we'd pull the engine and freshen it up too. So we did over last winter. Just honed cylinders, gave it new rings and bearings, and valve springs and timing chain. Threw it back together, then rebuilt the rear end with new bearings, and seals. Got everything hooked back up and fired it up. Set timing and took on a test drive. No power at all. Checked many different things. Fuel pressure, good. 38-40 lbs at idle. Fuel filter, changed. Spark plugs, all new, no misfiring. Compression test, 120 lbs in all 8 cylinders. Thought it was a little low, but it is the same through all 8. Then we checked vacuum....5-8 inches at idle. Booo. Horrible right? I'm thinking between 17-21 inches? So we've been searching for leaks. Can't seem to find any leaks. Even pulled the heads off, and intake, checked all gaskets, through new ones on after making sure timing chain is aligned. Threw it all back together and it didn't change a think. Well, it did, now idle vacuum is at 8-9 inches. Sooo I'm lost. Super frustrated. Can't figure this out. Just absolutely no power at all. Has trouble taking minor hills on the road. Won't even spin tires in the wet grass! Why has it got no power or vacuum? Am I forgetting something major? Need help or suggestions or advice from anyone please. Positive or negative at this point. Just very frustrated. Thanks in advance.
1988 Mercury cougar XR7- 302 bored .030 over, gt40p heads, F303, AlexsParts spring and seal kit, explorer upper and lower intake, 70mm tb, maf conversion, 75mm maf, fenderwell cai, 24 lb injectors, T5 conversion, bbk h pipe, Slp lm, 3.73 rear, 4 wheel disc conversion, 5 lug conversion. :D :D
This is a dumb suggestion, but is the intake tube to the MAF connected good and tight? I know after working on speed density 5.0s like ours, you forget that on a MAF engine it's required. I know when I bought my XR-7 I screwed around forever trying to get it to run before I noticed that the air tube was off at the bottom of the clamp.
CoogarXR : 1985 Cougar XR-7
Yeah, it's connected. No stupid suggestion man, at this point I could have forgotten something obvious. So any question or tip is appreciated. Haha. Yeah i checked. Made sure today when I was tinkering on it. I hopped in, threw it in reverse and tromped the gas, and it take prolly 3 or 4 seconds to Rev up and then another 2 or 3 to start moving. It's like in park/neutral it's slow to rev, then in gear, it takes forever to get moving. It accelerates like a slug on the run. Sooo I'm still lost. Haha
Sounds like the timing is way off
But we lined up the timing marks on the crank and cam. Factory crank and cam still. Could it still be off?
I was always taught dot to dot was leaving power behind. I don't know how to  degree a cam but have seen the difference it can make.
I thought of that, but then figured it ran just fine before tear down. That was with dot to dot. And now it's gutless. I just don't understand what could be causing the major vacuum drop. I didn't think degreeing was necessary until you throw in an aftermarket cam.
Maybe check EGR valve? or TPS sensor? Could also try spraying brake clean around the wherever the manifold meets the heads/TB and listen for increases in engine rpm
-Kyle
Dot to dot is how its done at the factory. Low vacuum will make the car run bad and rich, but shouldn't give up any power. Vacuum is a measurement of restriction. The less restriction you have, the more power you will have, for the most part.
For us 5.0 people, pull your map hose off. It will run like shiznit and shoot black smoke and stain the ground, but, under wot, it will run exactly as its supposed to. At wot throttle, you should have next to no vacuum. Most any vacuum leak will not effect wot performance. It's just like having that much more airflow.
120lbs of compression for a re ringed engine is still way low. But since all 8 were the same, it should be okay. My first 86 had 290k miles on it and still had around 100psi. Worth of compression.
What did you set your distributor timing to, and what codes does it pull? I also believe that the newer efi trucks were maf weren't they?
Where did you set the timing? Maybe set the timing by vacuum or ear.
Quote from: kylesburrell;450398
-Kyle
We ended up blocking off the egr to see if that fixed it. But it didn't change a thing. Didn't fuss with the tps yet. Could that be why vacuum is low? We did spray the heck out of it while idling with brake cleaner, but there was little to no change in rpms. No obvious difference.
Quote from: Haystack;450400
I'm not sure if it has a map sensor. It's a mass air, so would it have air bap? Not sure where it is. I'll have to check. I pulled the spout, and set to 10 degrees BTDC. Figured that was close. Lol
We're gonna pull the codes again soon. When I get back over there. Then I'll post findings
No MAP on mass air, the baro ain't gonna care...(be sure there is no vac connected to port)
Are you using the correct firing order??? Trucks went to the HO order with the switch to mass air...
That could easily be the whole issue.
