Topic: New to T-Birds and this forum (Read 6612 times) previous topic - next topic
Hello. Just wanted to thank everyone that has contributed with helpful data on this platform. I purchased an '88 T-Bird a month ago after searching for an LSC. So far my wife and 17 year old son have driven it more than me. Gathering parts and info for some upgrades. My other 2 cars require climbing over rollcages, and I wanted something a little more simple. Noticed a few members are located in Westminster, Maryland,  and I think the one car is only a few miles from me.
1988 LX, 306 with GT40P heads, Downs Upper Intake on Truck Lower, Powerdyne Supercharger and T5 swap.  Scavenger Hunt Build at it's best.
Quote from: Matt Jewell;450229
Yaayyy!!!!!! Check it out!!!!!  Another member in Westminster!!!!!!!
There's at least four other Cougars on this forum in Westminster that I know of.
Welcome to the forum. Glad you're here.
welcome
Welcome!!
tbirdregistry.com
26480
27373
Welcome
Welcome aboard.  Any pictures of your rides?
Not great at the computer thing. I have a '67 Cougar I've owned since the late '80's that has a 408 Windsor and runs high 10's on motor and high 9's with nitrous. Most recently I was racing a '80 Capri that I put together for my son that had a 514 CI BBF and ran high 9's. That car is about to get a milder 460 for my son to start racing. My brother and I are partners on a tube frame Mustang II that has a 460 and runs mid 9's. I have some parts for the T-bird, and swear to keep this a low budget/driver.
Welcome.
Swapped out the shocks and struts, front end links and repacked wheel bearings. Picked up an 8.8 housing, 4 lug Moser 31 spline axles and  Ford Racing posi unit used for $150. A friend donated a set of 3.55 gears, just need to pick them up. I believe he has Metco adjustable uppers and basic Lakewood lowers I can get for cheap as well. It's good to have friends.
Fox mustang lowers are a bit shorter then our cars. Make sure they are long enough, or it will effect your pinion angle.
Uppers are shorter as well.
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
Thanks for the heads up. Used that search feature and picked  up the measurements. The Metco uppers are adjustable, but if it's over 1'' difference I will need to check how adjustable. Also checked out the CHE website, wasn't even aware of the company. Our Capri has UPR adj. lowers, Comp Engineering uppers and anti-roll and Varishock coilover conversion. Next search will be frame connectors.
Mason Dixon Dragway in Hagerstown is having a Ford Meet August 23. Plan on meeting some friends to sell parts, and possibly see the maiden voyage of the T-bird down the 1/4 mile before swapping out the rear. I would be shocked if it ran  faster than 16 flat.
With a 5.0 slow? Probably looking at right around 17.
