Topic: 3.8 tbi (Read 1099 times) previous topic - next topic
3.8 tbi
is it possible from going to a TBI to something like a holly carb or somthing?
Re: 3.8 tbi
Yep, it can be done.  Check this out for the info.  If you're looking for a little more bump with a little less work in the conversion department, You should swap out the 3.8's Throttle body for the bigger 5.0 version.  It's a really easy swap and I'm guessing a junker's TB would be cheaper than a new holley carb.  If you have more questions about the TB swap, ask away, jcassity will more than likely jump on it.  If you still want to do the carb thing, the write up is linked above.  Thank you, come again.
1987 Thunderbird 3.8. Sold :(
