Topic: Turbo coupe tach (Read 2653 times) previous topic - next topic
Turbo coupe tach
I'm trying to resurrect the 4cylinder tach in the bird. Do the three posts in the back of the tach represent the three inputs?  I have 12v ground and tachout from ecu set to half speed to compensate. And it won't work. Is there a test to see is tach works?
Thought?
Turbo coupe tach
Bump
Turbo coupe tach
Try hooking to the tach/ground side of the coil instead of the ECU tachout.
If this gets the tach to move, then maybe the ECU tachout has the wrong voltage levels for this tach.
Turbo coupe tach
I was thinking same thing. I'll give it a shot tomorrow.
Thanks.
Turbo coupe tach
Tach works of neg side of coil. Jim's gonna make me a circuit to get it to half speed.
Turbo coupe tach
http://www.foxtbirdcougarforums.com/attachment.php?attachmentid=36526&d=1433588256 been staring at this for hours cant figure how it works?
Turbo coupe tach
Figured it out just cant make it work with what I've got hurry up and wait
