Topic: Panther tripmimders (Read 3599 times) previous topic - next topic
Panther tripmimders
How would I go about "flipping" the mounting brackets?
Current: 1986 Thunderbird, 105k 3.8/C5, 2 tone  Midnight Wine/Medium Taupe, wing windows, wire wheel covers.
Former: 1985 Cougar GS 115k Oxford White/Regatta Blue, 5.0, full console, 14" 8 hole aluminum T-Bird rims, Edelbrock valve covers.
Panther tripmimders
Can't you just modify your existing clock bracket?
Panther tripmimders
I think that coolcats has a good write-up on it... :)  Be careful of drilling or "digging around" with a screw driver--some of the electrical components and ribbon wiring are just beneath the housing at the area by the brackets.
Panther tripmimders
There are 4 on ebay right now, but they are all from Panther cars.
Panther tripmimders
From what i remember,the clock bracket looked almost identical. Mine was out of a tbird though, so o really didn't have to do much, save for wiring.
Panther tripmimders
I've done lots of Panther tripminder retrofits.  I've always found it very easy to just remove regular digital clock brackets and epoxy them on to the tripminder casing.
Panther tripmimders
it came today, got it all wired up, seems to work ok, but I gotta press some of the buttons pretty hard.
Panther tripmimders
You can take it apart and run a small piece of sandpaper between the button contacts.  That should remove the corrosion in there and make it so you don't have to press the buttons hard.
Panther tripmimders
^ Yup I had to do that when I got mine a while back, must of been sitting for a long time w/o use
Use something fine though like 1000 grit or so
Panther tripmimders
Make sure it reads accurate as well. I had to add a jumper to it. First testing was averaging 100+ mpg.
Panther tripmimders
Instant mpg was accurate, but average mpg was also saying 100 mpg, lol
Panther tripmimders
Yeah, i did a 1.8 mile drive. Short blast to a 60mph zone and when i got home i was averaging 134. Adding the jumper basically solved it
Panther tripmimders
Where do I add the jumper?
Panther tripmimders
Coolcats.net has a pinout and talks about the jumper.
