Topic: kamikaze crusie control (Read 5509 times) previous topic - next topic
it will not be until the weekend before i can get back to this will let you know then but im sure the crusie control works with the lights on.the two orange rear lights in the bumper are my turn signals
Quote from: mr glee;449900
Ok, you have separate orange lights for turn signals. The headlights will have no effect on cruise.
The fix is to reattach the green brake switch wire that was cut and to cut the green wire that goes to the multifunction/turn signal switch.
1. disconnect the negative battery cable.
2. unplug the connector with the two green wires from the cruise control amplifier.
3. with the ohmmeter function of your multimeter , check for continuity between the cut green wire and the green wires at the connector.
4. if you have continuity, you have to decide which of the two wires at the connector goes to the multifunction switch and which one to      the  cut.
You can physically follow the wire or cut one and hope you get lucky. check the continuity to see if you cut the correct wire. Guessed wrong? then cut the other wire and splice the first one you cut back together. Do not cut the wire too close to the connector, leave enough wire to work with in case you have to splice it back together.
5. Splice the cut green wire, where the yellow/green wire was added, back into the brake light circuit.
6. replug the cruise amp. connector.
7. reconnect the negative battery cable.
ok got that will do this at weekend as the job that has bin done on this is bad all connector blocks and joins will run new wire and solder the joins.will let you know the result.
thanks softouch all went well and now have brake cut out.no more spare pants for me.
Welcome. Your resume button should work now also.
