Topic: hard and delay shift (Read 1887 times) previous topic - next topic
1985 elan with 5.0 axod trans stuck in 1st gear until about 3000 rpms then hard shift any clues on what is  the fix
Probably the TV cable linkage. It might have come off the throttle body, or the lever on the transmission might be seized or sticking
Could be low on fluid too
CoogarXR : 1985 Cougar XR-7
Don't drive the car till you have checked this. It can burn up your transmission in just a few miles. My old crown vic had it come loose on my ex. In the 1/2 drive back from the gas station, it permanently started slipping after.
