Topic: fan isn't kicking on (Read 1515 times) previous topic - next topic
Okay I figured out why my car is getting so hot the fan isn't kicking on. When I first got it it was and sometimes it wouldn't shut off. Where should I start? Oh its an 88 turbo coupe by the way.
There is a fan controller under the dash (on my 86 it was behind the glove box). These are pr0ne to melting. There are threads here and on mustang forums about this. I bypassed mine with relays, since when it melted, it melted pretty good and distorted the connector. I figured it wouldn't make good contact with a new one (plus I heard the part-store replacements are unreliable (surprise!)).
You could also have a bad motor. My fan motor died, but not without a lot of tell-tale bearing squeal first. Easy enough to test, just disconnect it at the fan, and apply power and see if it runs.
I would think if it just suddenly doesn't turn on, it's the controller though.
CoogarXR : 1985 Cougar XR-7
Quote from: SR7188;448704
The fans are controlled by relays inside IRCM, if they run continually someone's been jerking with the wiring or relay(s) is stuck...
You'll need to do a code scan to see if they turn on during test(will be very brief)...  If you can't tell, ground pin #17(pink wire) on IRCM and lower fan should run continually...
If above checks out, the engine temp sensor between #2 & #3 injectors is probably bad(no they won't always set a code)...
