Topic: 1987 cougar 3.8 where can I find the right fuel gage sending unit (Read 2162 times) previous topic - next topic
Hi I just joined and I have a 87 cougar 3.8 it has 66000 mile on it and sat for ten years I replaced the tank and sending unit. The sending unit I put in it was for a mustang and dont work. It could not find one for this car anywhere
Amazon have one for $107....
How fast is fast?
also depends on which dash package you have. The full digital panels use a different sending unit than the buttstuffog gauge.
The full digital senders are not available.
If you search the forums, you'll find multiple posts which basically say this:
Quote from: EricCoolCats;400059
There are several different sized tanks for our cars, and also a change in resistance for the fuel level senders. BE SURE you get the correct sender for your year/gauge/engine!
1983-86: 75 Ohms empty, 10 Ohms full
1987-88: 16 Ohms empty, 158 Ohms full
Then you can search through this page to find the sending unit that has the same readings as what you need:
http://www.latemodelrestoration.com/products/79-93-Mustang-Gas-Fuel-Tank-Sending-Unit
Finally, when you get your mustang one, make sure you bend the bracket to match the bottom and top of your tank.
If yours isn't a rusty piece of  like mine was, you can likely just clean and adjust your contacts (they are simple devices) and reinstall.  Again, instructions are on the board with a little search power.
T-Birds can't fly.  Ask how I know...
