Topic: 1988 ford thunderbird fuel pump not turning on (Read 1787 times) previous topic - next topic
So I just replaced the fuel pump in my 88 Tbird and everything was working great until a week into having the new one when the car wouldn't start after I was done with work. I came back the next day to take a look and it fired back up.now it's doing again but won't start so I replaced the relay and checked the inertia switch and still nothing. Any ideas? Maybe a grounding issue?
Is it priming but won't start or is it not priming at all?
1988 Mercury cougar XR7- 302 bored .030 over, gt40p heads, F303, AlexsParts spring and seal kit, explorer upper and lower intake, 70mm tb, maf conversion, 75mm maf, fenderwell cai, 24 lb injectors, T5 conversion, bbk h pipe, Slp lm, 3.73 rear, 4 wheel disc conversion, 5 lug conversion. :D :D
Was it an airtek pump? I helped swap one in and it only built up to 8psi brand new out of the box. $10 more got us a walbro.
