Topic: Service light on (Read 2290 times) previous topic - next topic
Service light on
Hey all,
The service light below the speedometer started coming on when I start my '85. It stays on for a few minutes, then goes off.
Is this the same as the check engine light? Does it store diagnostic codes or does the light have to be on when I hook up the scan tool?
Thanks in advance.
Cornfed85
1985 Thunderbird - 3.8 V6, C5  :ford:  :birdsmily:
Service light on
That light is just a maintenence reminder.
Current: 1986 Thunderbird, 105k 3.8/C5, 2 tone  Midnight Wine/Medium Taupe, wing windows, wire wheel covers.
Former: 1985 Cougar GS 115k Oxford White/Regatta Blue, 5.0, full console, 14" 8 hole aluminum T-Bird rims, Edelbrock valve covers.
Service light on
Oh ok. Thanks
Cornfed85
Service light on
Quote from: 1985Elan;448237
Hey all,
Thanks in advance.
First I have heard of a service light on these cars. Does say "service" on the light or is it maybe "check oil" or "low fuel" or "washer fluid" ?
Service light on
1985-88's with the base, or full digital clusters, comes on every 7500 miles or so.
Service light on
The service light stays on for a while, it will eventually disappear, but it should stay on continuously, not turn off after a few seconds. I believe you clear it with the trip and trip reset button at the same time. If that doesn't clear it, that's not it.
The service light shows up on the green portion of the speedo. If your getting a yellow light it would be a code.
