Topic: 87-88 5.0 Cruise control cable. (Read 1138 times) previous topic - next topic
Need a cruise cable. Modded one from a different car to work, but its now hitting stuff with my kenne bell install.
Thanks,
Chris
87 Thunderbird 5.0
Engine: 97 p-code explorer block, heads, and intake; 88 HO cam, 1.7 RR's, A9P, Kenne Bell 2.1 Flow/Blow 8psi, 42lb injectors, LMAF, 75mm TB, Tuned by Don Lasota
Trans: 02 Stang 4r70w with Baumann TCS
Suspension: Front: 03-04 cobra springs and struts, TC rack. Rear: CHE arms, ChuckW shock mounts, Bullitt springs and shocks
5 bolt with 95 mustang front and mark vii rear.
TC 3.73 L/S rear
03-04 SVT Cobra 17x9's with 275/40r17's.
Got one, Thanks
87 Thunderbird 5.0
TC 3.73 L/S rear
do you have the 17x9s w/the 275s on all 4 corners? Pics please?
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
I do. The rear fits perfectly with the mark VII axle. The front is a bit too wide with the SN95 spindles. The drivers side is right even with the fender, and the passenger side sticks out half an inch.
The body on my car is complete junk, so not a great example of fitment.
I replaced the passenger fender with a junkyard unit from an earlier car, I believe thats the issue there. It had what appeared to be fire ax damage when I bought it.
I can snap some fitment pics tomorrow, but again, my car isn't a great example.
87 Thunderbird 5.0
TC 3.73 L/S rear
