Topic: '86 Cougar 5.0 V8 - Rough idle after starting (only when motor is warm)... (Read 3396 times) previous topic - next topic
Hey everyone!
I'm having a problem that I'm scratching my head trying to figure out.  I had posted a month or so that I had changed my spark plugs as they were the original spark plugs that came on the car.  I have an '86 Cougar 5.0 V8.  I get smooth idle when I first start the car for the day.  If I go somewhere after the motor has warmed up, then come out to start the car again, it idles pretty rough (rumbling and bumbling the way it feels), almost to the point it acts like it wants to cut off.  I haven't changed the spark plug wires, distributor or rotor.
Anyone got any ideas?  Any help would be greatly appreciated!  :-D
Thanks in advance,
Tommy
Replace your wires, cap and rotor. Check your coil and take your ign. module to autozone to get tested.
How fast is fast?
Where do you find the coil and ignition module?  My other question is, will the car shut off while it's still doing this?  So far it hasn't, but I'm wondering if it might.  Money is tight right now, so I can't change out a lot of parts on it.
Do you have any check engine lights, does it smoke?
How fast is fast?
No check engine lights and it doesn't smoke at all.
Does it eventually smooth out? Or do you have to wait until it cools off?
CoogarXR : 1985 Cougar XR-7
As long as the motor is warm, it will continue to do it.  If it's cold, whether starting it for the first time, or after the motor has cooled down, it's smooth.
If you start the car cold, and drive it until it gets warm, but don't turn it off, is it still fine? Or will it start acting up as it's heating up?
From what I can tell, it's still fine if I don't turn it off.  I'll check for sure either later this evening or tomorrow.
What about the TFI module?  I think they can act up when hot.
Mike
Where's the TFI module?
Quote from: thetommyboy2k;447339
It's mounted on the side of the distributor
If you replace it, it is generally accepted to use only a Motorcraft piece, not aftermarket/parts store junk.
Mike
