Topic: AOD whinning (Read 2422 times) previous topic - next topic
AOD whinning
Hi Guys,
lately when i get in the higher rpms i can hear my transmission whinning. Im terrified to think about what could be wrong in there. Possibly worried about the clutch packs? I dont really know transmissions very well.
Thanks for whatever help youve got.
Kyle
AOD whinning
All AODs normally have a whining sound when accelerating. If it's getting louder it could be the transmission pump. If your AOD has 326,000 miles on it and hasn't been rebuilt it could very well be the pump starting to go out ;).
AOD whinning
its been rebuilt twice in its life. first was right after mom/dad bought it (covered under warranty) and then it was rebuilt again at 200K. And the other thing that happens sometimes, is I can give the car more throttle and it doesnt accelerate more. Just keeps on at the same speed. Then after a few seconds itll "pull" again.
AOD whinning
Was it low on oil for a while? A clogged filter will do that. If it a stk. aod , There week. You sure the cable is still connected to the TB?
AOD whinning
the aod in my vert whines like a little girl in OD
