Topic: Tail lamp fuse (Read 10767 times) previous topic - next topic
Tail lamp fuse
I noticed I don't have tail lamps when I turn my marker lamps on. I pulled the fuse and it was blown. So I put another 10 amp fuse in and it popped as soon as I hit the light the marker lights. My best guess is would it be a short to ground? Can anyone give ideas what it may be? Thanks for the help.
1988 Mercury cougar XR7- 302 bored .030 over, gt40p heads, F303, AlexsParts spring and seal kit, explorer upper and lower intake, 70mm tb, maf conversion, 75mm maf, fenderwell cai, 24 lb injectors, T5 conversion, bbk h pipe, Slp lm, 3.73 rear, 4 wheel disc conversion, 5 lug conversion. :D :D
Tail lamp fuse
If you've been working under the dash, you might have pinched a wire. I know one time I dropped the steering column in my mustang and pinched one of the lighting wires in the bracket when I put it back up. Shorted, smoked, scared me to death, thought my car was on fire, etc. Good times.
CoogarXR : 1985 Cougar XR-7
Tail lamp fuse
That could be exactly what happened. I was messing under the dash alot. I'll have to follow the wires. Thanks CoogerXR
Tail lamp fuse
Brown. Got it. Thanks Trinom
Tail lamp fuse
X
So while using this schematic as a guide, I turn on my parking lights, and I have them up front, along with marker lights. The tail lights however are alll out. When I put a new fuse in and it blows as soon as it turns on, it tells me that it is short to ground on the brown wire. But because only the tail lights don't work, does that mean that the short is between the fuse and the tail lights? Or could the short be between the fuse and the light switch? I thought if it was the latter, then no lights would work. Am I correct?
Tail lamp fuse
Yes, the short is below fuse 15 in the diagram.
That also includes the lamp-out warning module as well as the bulbs.
Tail lamp fuse
Oh alright. That is great info. I was unaware of that since it doesn't appear that way on the diagram.
Tail lamp fuse
Also check the light blue w/ red stripe wires under the dash and behind the radio. These are the dash illum + wires. They show ground when the lights are turned off causing them to be used as ground when hooking up accessories like gauges or radios. I install car audio and see this mistake quite often. This will also cause the tail lamp fuse to blow in most cases.
Tail lamp fuse
Here's a random thought....some guys at work said it could be my tailights bulbs themselves? That they may be grounded through the bulb? And if I bulb shorted, that could be blowing the fuse. Is this myth? Or could this be possible?
Tail lamp fuse
I've never seen it on any of my cars, bit it is possible.
Do this first.
You have both illumination and brake light signal wires for power. To blow a fuse, it pretty much has to be grounded out. Check for negative on your tail lights first. If you have a ground, you know both which wire it is, and that it is somehow directly shorted out
Tail lamp fuse
Quote from: Haystack;448135
I'm sorry to be ignorant, but I'm a bit cloudy with how to go about checking for negative on the tail lights. Please inform me on how to do this. Sorry again
Tail lamp fuse
Quote from: FOX-XR7;448122
Probably more myth than reality... Easy to test, remove all the bulbs on the supply side of F15(to the south of fuse), if fuse still blows, that ain't the problem...
If signal & brake lights are normal, not likely a problem with the tail lamp bulbs, though I have seen a busted bulb cause a short(start checking side marker, license, etc bulbs)...
My bet is there is a pinched brown wire somewhere between fuse and tail lamps...
BTW assuming you have the feature, there is a possibility of a issue with the lamp out module...
Tail lamp fuse
Huh?? Ground supplied to bulbs is same as a connection to body/chassis, if it shorts to body no foul, no harm... If ground were shorted to supply(brown wire, or a internal short in bulb), it's still same as supply wire shorting out to ground...
If ground were missing the lights would not burn but would not blow the fuse... I had this problem with backup lights on the '95 LX, ground wire to sockets was broken at trunk hinge...
Tail lamp fuse
Sorry, i didn't describe that properly.
Grab your volt meter and check your positive wires at the tail light, and look for a ground on the positive wires. You have the illumination lights, turn signal or brake wire that could be shorted out.
You can either do a resistive test from a good know ground, or find a power wire that works and see if you have voltage, looking for ground on a positive wire. That way you can at least rule out the other wires, and measure different parts of the car to see where the fault is. Worst case scenario, you figure out which wire is bad and run a new wire to replace it.
