Topic: Master Cylinder W/ ABS (Read 1672 times) previous topic - next topic
The master cylinder went out in my 1987 Turbo Coupe, and I'm having one hell of a time trying to find a new one.
Does anyone know the part number for this or even where I can find/ buy one??
Thanks, trying to get this turd back on the road before winter comes again.
Quote from: Gekell;445797
Well good luck, it's Turbo Coupe specific and AFAIK is long since discontinued(one from similar year LSC may work but AFAIK aren't available either)... Most just swap to a vacuum booster and conventional MC but that does require a bit of plumbing work...
In the real world those rarely fail, generally the relay that operates the pump fails so there is no boost assist... Relays are just a few bucks...
By chance could you direct me to a thread with the swap to a vacuum booster system?
Much appreciated!
Use the search button after you read up on these two threads and you will get some more hits:
http://www.foxtbirdcougarforums.com/showthread.php?36816-Converting-Teves-II-ABS-to-regular-power-brakes
http://www.foxtbirdcougarforums.com/showthread.php?32449-teves-to-vacuum-assist-a-few-questions&highlight=teves+booster
The Teves I I master cylinder (used in the Turbo Coupe and Mark VII) is avaliable rebuilt for around $900.
For $900 I'd rather spend my money and massively upgrade my master cylinder to something from a high end company.
I'll probably be going down the conversion road, thanks again for the links Aerocoupe!
