Topic: Got the new alt & tensioner on but... (Read 1745 times) previous topic - next topic
I broke the tensioner tightening bolt off, how would you guys go about fixing this?
Current: 1986 Thunderbird, 105k 3.8/C5, 2 tone  Midnight Wine/Medium Taupe, wing windows, wire wheel covers.
Former: 1985 Cougar GS 115k Oxford White/Regatta Blue, 5.0, full console, 14" 8 hole aluminum T-Bird rims, Edelbrock valve covers.
Flap disc, clean the coating off, reweld with penetration.
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
Ok, but it should be ok for now, right?
If the belt is tight and you have it locked down with the other fasteners it should be fine.
It is, thanks.
Can you exchange the tensioner for a new one?
I got the parts from RA, but yeah, I should be able to.
So that nut just pushes against the tensioner to push the belt down and keep it tight, right? You could try putting another nut behind the "broke" one. the second nut would lock it in place
Id just swap the nut from over the top of the bracket where the weld broke to underneath it. Hold it in place/position with a wrench, tighten it down with a ratchet, call it a day.
Quote from: Haystack;444856
Yeah, that's what I was thinking too, hopefully the bolt is long enough.
